Shift kit for 02 "X" v-10 / Pros - Cons
Thread Statistics:     Users to Post: 2   |   Total Posts: 2   |   Total Views: 715
TrickyTryler
• Carlisle, PA, USA
• Registered on 2/18/2009
• 14 posts
Posted:1/27/2010 10:15
Has anyone installed a shift kit on thier V-10 "X"?
I pull a 18' enclosed trailer loaded with cycles.
Plenty of hills around PA that work the converter more than I like, just thinking a shift kit might help it spend less time working the converter.
Looking for any comments.
aklim
• Hartford, WI, USA
• Registered on 2/20/2006
• 133 posts
Posted:1/27/2010 10:41
If you give Brians Truck Shop a call at 870-422-3673, he can sell you a Valve Body. The install is simple. http://www.guzzle7pt3.com/bts.php
Also, you can call Jody at DP-tuner and have him put a tune on your PCM if you like,.
